[postgis-devel] Reg : Error while doing " create extension postgis; "
    Stephen Woodbridge
    woodbri at swoodbridge.com
    Sun Jan 26 07:34:23 PST 2014
Manikanta,
Looking at your error message again, it looks like you system has a mix
of code installed from source in /usr/local/lib and some from packages
and they are getting mixed up.
I run Ubuntu 12.04 LTS and regularly compile  pgrouting without any
problem, but I do not have anything in /usr/local/* that might conflict
with the packages installed.
-Steve
 >      >>> Error :    could not load library
 >      >>> "/usr/lib/postgresql/9.1/lib/rtpostgis-2.0.so
 >     <http://rtpostgis-2.0.so>
 >      >>> <http://rtpostgis-2.0.so>": /usr/local/lib/libgdal.so.1: version
 >      >>> `GDAL_1.8' not found (required by
 >     <http://rtpostgis-2.0.so> <http://rtpostgis-2.0.so>)
On 1/26/2014 1:53 AM, Manikanta Kondeti wrote:
> Hello sir ,
> I'm using Ubuntu 12.04 . I remember that I had same problem  with QGIS
> last time when I added this repositories. Tillmill is working in my lab
> system & its not working in my system .  Anyway I will add this
> repositories  & do my other work in lab . But just tell me if there is
> any alternative way that I can work on both or should I update to Ubuntu
> 13.04 ? .
> Thank you
> Manikanta
> Spatial Informatics
> IIIT-H
> On Sun, Jan 26, 2014 at 10:16 AM, Daniel Kastl <daniel at georepublic.de
> <mailto:daniel at georepublic.de>> wrote:
>     Hi Manikanta,
>     Which version of Ubuntu do you have troubles with?
>     I remember that last year there was a change in the package naming of
>     GDAL UbuntuGIS packages. So when I installed PostGIS 2.x it
>     uninstalled QGIS. Still I have some troubles with Tilemill package for
>     example, which requires the "original" package.
>     For pgRouting though this should be resolved. CMake is only too old
>     for Ubuntu 12.04, but there is a newer version in the pgRouting PPA.
>     Daniel
>     On Sun, Jan 26, 2014 at 5:53 AM, Manikanta Kondeti
>     <mani.iiit123 at gmail.com <mailto:mani.iiit123 at gmail.com>> wrote:
>      > Hello sir ,
>      >       I heard that if add that repositories  cmake wont work & it
>     will
>      > remove all libraries linked with it . I have done a web
>     application using
>      > pgrouting in oct & nov , at that time I remember I had these
>     libraries in my
>      > system and it worked perfectly . In this month I was about to do
>     my lab work
>      > which needs cmake  , so I installed it again & it removed all the
>     libararies
>      > linked with pgrouting . I got this information from ubuntu people
>     in IRC. Is
>      > there any alternative way ,   Now what shall I do ??
>      > Thank you ,
>      > Manikanta
>      > Spatial Informatics ,
>      > IIIT-H
>      > On Sat, Jan 25, 2014 at 7:52 PM, Stephen Woodbridge
>      > <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>> wrote:
>      >> On 1/25/2014 5:46 AM, Manikanta Kondeti wrote:
>      >>> Hello ,
>      >>>       I am getting this error while installing a pgrouting
>     algorithm
>      >>> which is developed last year . I have also attached a
>     screenshot of it
>      >>> which shows the error .
>      >> I would recommend adding adding the following ppa's
>      >> http://ppa.launchpad.net/georepublic/pgrouting/ubuntu precise
>      >> http://ppa.launchpad.net/ubuntugis/ppa/ubuntu precise
>      >> http://apt.postgresql.org/pub/repos/apt/ precise-pgdg
>      >> This should make the latest gis stack available on Ubuntu.
>      >> -Steve W
>      >> _______________________________________________
>      >> postgis-devel mailing list
>      >> postgis-devel at lists.osgeo.org <mailto:postgis-devel at lists.osgeo.org>
>      >> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
>     Georepublic UG & Georepublic Japan
>     eMail: daniel.kastl at georepublic.de <mailto:daniel.kastl at georepublic.de>
>     Web: http://georepublic.de
