[postgis-devel] ST_LineLocatePoint with empty geom raise error
Rémi Cura remi.cura at gmail.com
Fri Jul 11 01:11:26 PDT 2014
Not willing to put a fight,
but I think the standard behaviour for logic of (TRUE,FALSE,NULL) in
postgres is whatever involves NULL is NULL.
By extending this concept to null geom, one should expect a null output.
And i don't feel it should be this function that forces you to take special
care of empty geometry.
If you are worried about empty geometry for your special case, you can
still filter it befor or after (with a where result is not null on result !
That being said, I don't see major interest in empty geom instead of null ..
Cheers,
Rémi-C
Cheers,
Rémi-C
2014-07-10 23:31 GMT+02:00 Sandro Santilli <strk at keybit.net>:
> On Thu, Jul 10, 2014 at 01:45:49PM -0400, Paragon Corporation wrote:
> > or Empty happy. It should be a POINT EMPTY of course :)
> ST_LineLocatePoint retuns a floating point number between 0 and 1.
> --strk;
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20140711/05a1c6d3/attachment.html>
