[postgis-devel] Regarding Sp-gist implementation in postgis]
maplabs at light42.com maplabs at light42.com
Mon Jul 28 08:45:27 PDT 2014
I built and executed a Postgres from source during a code sprint for
the Postgres project, however it was tricky.  I recall I executed many
steps as the linux postgres user.
you can definetly get 24 hour support on building and running postgres
from source on freenode IRC #postgresql
I use Firefox Chatzilla plugin.. it is built into SeaMonkey if you want
to have a really simple way to get Chatzilla.. otherwise install the
Chatzill extension, restart Firefox, open Chatzilla from Tools menu,
click on Freenode
/nick mohitkumar
/join postgresql
 -Brian
On Mon, 28 Jul 2014 17:49:47 +0530, mohit kumar  wrote:
       Reseting the conf file also gives the same output.
The restored configuration file is as http://pastebin.com/HA5ujeXT
Also, in which file the debugging prints need to be inserted? adding
prints in postgis/sp_gist.c are not working. DO they need to be
inserted in postgis.sql.in file?
Regards,
On Mon, Jul 28, 2014 at 4:23 PM, Sandro Santilli  wrote:
       On Mon, Jul 28, 2014 at 04:05:14PM +0530, mohit kumar wrote:
> On 25 Jul 2014 13:13, "Sandro Santilli"  wrote:
> > On Fri, Jul 25, 2014 at 08:35:08AM +0530, mohit kumar wrote:
> > > file(/usr/local/pgsql/data/postgresql.conf) are pasted at
> > > http://pastebin.com/eaX383cw.
> > The paths for "hba_file" and "ident_file" and "data_directory" all seem
> > to be relative, so would resolve based on where you are when you start
> > postgres. As you're starting it from ~/builds/source/postgis, I dubt
> > you have ~/builds/source/postgis/ConfigDir, which would explain the error.
> The error is coming even after removing the path for hba_file and
> ident_file.
See if there are other relative paths, paste new config again.
Reset the config to default as last resort.
Try also another path if this one (valgrind) is too hard for you:
add debugging prints into the code to see which parts of the code
are executed and which not.
Try more things, try harder.
--strk;
 ()  ASCII ribbon campaign  --  Keep it simple !
 /\  http://strk.keybit.net/rants/ascii_mails.txt
Mohit Kumar+91-970-3840-175Lab For Spatial Informatics
International Institute of Information Technology
Hyderabad, India
postgis-devel mailing list
postgis-devel at lists.osgeo.org
http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20140728/ff8f97c5/attachment.html>
