[postgis-devel] [SoC] "Gsoc weekly report 4": Implement sp-gist clustering in PostGIS and cartoDB
Sandro Santilli
strk at keybit.net
Wed Jun 25 02:55:04 PDT 2014
Mohit, any news about sp-gist indexes support on Geometry ?
Midterm evaluation is due in 2 days ...
I'm looking forward for a pull request adding that.
--strk;
On Wed, Jun 18, 2014 at 07:11:26PM +0530, mohit kumar wrote:
> Thanks Strk,
> Will revert back to you in a day.
> Regards,
> Mohit
> On Jun 18, 2014 6:56 PM, "Sandro Santilli" <strk at keybit.net> wrote:
> > On Wed, Jun 18, 2014 at 06:05:34PM +0530, mohit kumar wrote:
> > > Hi Strk,
> > > Can you give me some references on how to write a postGIS connector and
> > > what exactly do we want. I am getting confused in a lot of things.
> > We want to be able to do:
> > CREATE INDEX ON the_table USING spgist (the_geom);
> > Then, (second step?):
> > -- This query should use the spgist index
> > EXPLAIN SELECT * FROM the_table WHERE the_geom && <small_bbox>;
> > --strk;
