[postgis-devel] Extension test
Sandro Santilli strk at keybit.net
Fri Mar 28 12:47:53 PDT 2014
Unfortunately, it looks like while the variable substitution
works with psql 9.3 it fails with 9.1 :(
https://travis-ci.org/postgis/postgis/builds/21785069
Sorry for breaking the testsuite right before release.
Could be a matter of a few minutes or more, not sure.
--strk;
On Fri, Mar 28, 2014 at 08:24:29PM +0100, Sandro Santilli wrote:
> As of r12379 the 2.1 branch "almost succeeds" running
> the full testsuite with the --extensions run_test.pl
> switch.
> Try it !
>  make check RUNTESTFLAGS="--extensions"
> The only failure I get is a mismatch of objects count
> before and after testsuite run:
>  uninstall .. failed (Object count pre-install (4112) != post-uninstall (4113))
> From here to figure what object has been installed that didn't
> belong in the regression I hadn't checked yet, but we're very
> close to be able to implement a post-install-check rule
> in Makefile.
> Help is welcome, while I sleep or over the week-end :)
> --strk;
>  ()  ASCII ribbon campaign  --  Keep it simple !
>  /\  http://strk.keybit.net/rants/ascii_mails.txt
