[postgis-devel] Grid-based Landuse and attributes
maplabs at light42.com
Wed May 21 09:14:40 PDT 2014
in 2011 / 2012, I was lead technical implementor for a study of land
use, jobs, housing, energy use and transportation in California, using
a 150 meter grid. The 'grid' was a refrerence set of geometry, each
resembling a box, in EPSG:3310. It is reference because the ID of each
grid cell is known in the state capital GIS data, such that an urban
planner in San Diego could refer to box ID 100, and it is the same grid
cell as a planner in San Francisco would see.
This project resulted in five primary result tables, covering the five
major urban centers of California:
http://blog.light42.com/wordpress/?p=1439
You can see an example of the SQL here, and in other posts:
http://blog.light42.com/wordpress/?p=1489
The study has since changed contents, but continues to this day, based
here in Berkeley
Brian M Hamlin
OSGeo California Chapter
blog.light42.com
On Wed, 21 May 2014 17:12:50 +0400, Alexander Korotkov wrote:
On Wed, May 21, 2014 at 1:02 PM, Jeremy Palmer wrote:
Hi PostGIS Devs,
I have a daily process that I would like to optimise. The process
includes a spatial intersects join between a small administration
boundaries table for New Zealand that contains large geometries
(100,000+ points per polygon) and a large dataset with small line
strings.
The first iteration of SQL I developed for the process I used
standard join (WHERE ST_Interesects(admin.geom, other.geom)) and it
took 4 hours to complete. No spatial index was used. Not acceptable.
So, your task is so-called "spatial join". We are now doing researches
on it. It would be nice if you could share your dataset so we can do
experiments on it.
With best regards,
Alexander Korotkov.
postgis-devel mailing list
postgis-devel at lists.osgeo.org
http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20140521/81c7a067/attachment.html>
