[postgis-devel] ST_OrderingEquals and memcmp
Sandro Santilli strk at keybit.net
Mon Nov 17 09:29:25 PST 2014
On Mon, Nov 17, 2014 at 09:03:49AM -0800, Paul Ramsey wrote:
> There’s only one pad hole, it's for polygons with an odd number of rings. I don’t know why it wouldn’t be consistently zero’ed out, since the pad is set with
> 		memset(loc, 0, sizeof(uint32_t));
The failure I saw was with point, some test under sfcgal.
But maybe it was my own implementation failing.
Shall I re-try and push the change as soon as it succeeds here ?
Would you like such a dropping-code change ?
In git terms:
 1 file changed, 5 insertions(+), 26 deletions(-)
--strk;
> Paul Ramsey
> http://cleverelephant.ca
> http://postgis.net
> On November 17, 2014 at 7:12:49 AM, Sandro Santilli (strk at keybit.net) wrote:
> I was reading the implementation of ST_OrderingEquals and wondered
> why we're not using memcmp on the serialized memory.
> Saint testsuite revealed it can sometime fail.
> I guess the reason for that is some "holes" in the serialized format
> left for alignment purpose, does it sound correct ?
> Could we ensure serializers fill any hole to speedup identity checking ?
> --strk;
> () Free GIS & Flash consultant/developer
> /\ http://strk.keybit.net/services.html
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
