[postgis-devel] Status of (constrained) triangulation functions
Rémi Cura
remi.cura at gmail.com
Fri Nov 21 06:26:58 PST 2014
Maybe it could be an easy adition to st_tesselate (SFCGAL).
CGAL already deals with line constraints, even intersecting.
*http://doc.cgal.org/latest/Triangulation_2/index.html#Section_2D_Triangulations_Constrained_Delaunay
<http://doc.cgal.org/latest/Triangulation_2/index.html#Section_2D_Triangulations_Constrained_Delaunay>*
Cheers,
Rémi-C
2014-11-21 14:32 GMT+01:00 Sandro Santilli <strk at keybit.net>:
> On Fri, Nov 21, 2014 at 02:26:07PM +0100, Tom van Tilburg wrote:
> > At the moment I'm spending the largest part of my 500 lines of SQL
> > for getting the triangles to follow the polygon borders and it
> > results in both expensive and difficult code. I know that JTS is
> > actually able to do it for a long time
> http://lin-ear-th-inking.blogspot.nl/2009/04/delaunay-triangulation-in-jts-111.html
> > but afaik it's never been ported to GEOS.
> JTS does actually not implement constrained triangulation:
> http://lin-ear-th-inking.blogspot.it/2009/04/delaunay-triangulation-in-jts-111.html?showComment=1294900721427#c629770929158824093
> The JTS implemented part was ported to GEOS already.
> > My company is willing to pay for further development of
> > triangulation, depending on the cost.
> The usual path is getting it done in JTS, then ported to GEOS
> and then finally exposed in PostGIS. Adding Martin Davis
> in Cc, in case he's not reading the lits.
> > P.S. afaik tessellate is with a double 'L'. Should I file a report
> > about that?
> Yes please
> --strk;
> () ASCII ribbon campaign -- Keep it simple !
> /\ http://strk.keybit.net/rants/ascii_mails.txt
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20141121/d4505719/attachment.html>
