[postgis-devel] Address_standardizer extension fully integerated into configure and set to auto-build
Sandro Santilli
strk at keybit.net
Wed Oct 8 03:55:15 PDT 2014
On Wed, Oct 08, 2014 at 12:49:23PM +0200, Sandro Santilli wrote:
> On Tue, Oct 07, 2014 at 11:37:31PM -0400, Paragon Corporation wrote:
> > I think I have a --without-address_standardizer if for whatever reason
> > people run into problems and need to turn it off. I didn't test that though
> > so haven't documented it yet. Not sure if its even needed.
> This did not work. You were using "address_standardizer" as a variable but
> the variable name would be "with_address_standardizer". I've fixed with
> r13051, you can now document "--without-address-standardizer" (all dashes,
> no underscores).
BTW, I've found this guide which is pretty nice:
https://autotools.io/autoconf/index.html
Now let's get autotools some more love !
--strk;
() ASCII ribbon campaign -- Keep it simple !
/\ http://strk.keybit.net/rants/ascii_mails.txt
