[postgis-devel] Transifex, translation and branches
Sandro Santilli strk at keybit.net
Sat Oct 18 04:21:23 PDT 2014
On Sat, Oct 18, 2014 at 06:21:31AM -0400, Paragon Corporation wrote:
> Which automation rule?
I was talking about the one mentioned by George, which I think
originates on Transifex.
> The translation job I have deletes all unversioned files first and then does
> an svn update.  I could change it to just always do an svn full checkout or
> is that not necessary?
No, don't change it.
I found another reason why the text is not replaced even if template
is updated: "fuzzy" keyword in the section.
This is how Paul's section looks like:
  #. Tag: para
  #: introduction.xml:58
  #, fuzzy, no-c-format
The "fuzzy" keyword means that the old translation was kept but the
original text actually changed (content or position) so it needs
a review. It looks like po2xml just does not take those ones as
good enough to be used in output, and thus skip them.
Taking the "fuzzy" keyword away make them back ready to be used.
I guess Transifex would use that keyword too, maybe to specify
if a translation was "reviewed" or not ?
--strk;
  ()   Free GIS & Flash consultant/developer
  /\   http://strk.keybit.net/services.html
