[postgis-devel] Sharding Rasters in Postgis
David Haynes II dahaynes at umn.edu
Tue Sep 23 14:11:10 PDT 2014
Yes, we are going to use the more finished product Postgres-xl, but even
that is not production ready.
So I would think the most logical solution is to generate the process
ourselves.
Mostly wondering how to distribute the tables to various locations, once I
do the difficulty part of aligning tiles to exist with a defined coordinate
space.
On Mon, Sep 22, 2014 at 11:12 AM, Rémi Cura <remi.cura at gmail.com> wrote:
> Do you mean somethiong like postgres-xc :
> http://postgresxc.wikia.com/wiki/Postgres-XC_Wiki
> Cheers,
> Rémi-C
> 2014-09-22 17:04 GMT+02:00 David Haynes II <dahaynes at umn.edu>:
>> Hello,
>> I was wondering if there any helpful examples for distributing rasters
>> tables in postgis. Are there other items that I need to consider? Will the
>> PostGIS functions need to be re-written if we want to parallelize the
>> processing, using something like pg_proxy?
>> I came an example using a different software package, (slide 16)
>> http://spark-summit.org/wp-content/uploads/2014/07/Geotrellis-Adding-Geospatial-Capabilities-to-Spark-Ameet-Kini-Rob-Emanuele.pdf
>> I would prefer to stay within postgresql community.
>> David Haynes, Ph.D.
>> Research Associate Terra Populous
>> Minnesota Population Center
>> postgis-devel mailing list
>> postgis-devel at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
David Haynes, Ph.D.
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20140923/e7577ce3/attachment.html>
