[postgis-devel] ST_Contains / ST_Within
Paul Ramsey
pramsey at cleverelephant.ca
Fri Sep 26 14:51:22 PDT 2014
I was just working through strategy numbers and thinking about how we only ever use RTOverlapStrategyNumber when I realized that we should be using other strategies for at least a few of our functions, and yet we have
CREATE OR REPLACE FUNCTION ST_Contains(geom1 geometry, geom2 geometry)
RETURNS boolean
AS 'SELECT $1 && $2 AND _ST_Contains($1,$2)'
LANGUAGE 'sql' IMMUTABLE;
When really it should be
RETURNS boolean
AS 'SELECT $1 ~ $2 AND _ST_Contains($1,$2)'
Probably a small efficiency savings to be had in reducing the number of geometries to be exact tested. Anyone see a reason we shouldn’t do this?
P.
Paul Ramsey
http://cleverelephant.ca
http://postgis.net
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20140926/0b6d9ba8/attachment.html>
