[postgis-devel] How to recreate comments?
Paragon Corporation
lr at pcorp.us
Mon Sep 29 12:00:46 PDT 2014
Nicklas,
> I guess something is going on (or not going on ) in my installation. It
> has worked before, or I wouldn't have had a working extension
> installation.
> make[3]: Entering directory `/opt/dev/postgis/test/doc'
> make[3]: Nothing to be done for `comments'.
> make[3]: Leaving directory `/opt/dev/postgis/test/doc'
Hmm I think you found a bug. I just looked at mine and noticed my
postgis_comments.sql is old dated 7/23/2014
But my postgis-out.xml is 9/24/2014.
I'm pretty sure I've been doing make clean. Though have to verify.
I think last change that was made was not to build comments during make
install because people said install should
Just install stuff not build anything. So maybe that isn't working right
> Is it ok if I just commit it otherwise. That breaks the build since
> the upgrade script won't work without the right comments (I
> experienced:-) )
Yes go ahead. NO big deal if you break the build in trunk.
I promise not to shoot you :)
Regina
