[postgis-devel] Collapsing behavior for simplify
Nicklas Avén nicklas.aven at jordogskog.no
Sat Apr 4 14:11:29 PDT 2015
Then I am on the right track with SimplifyVW. But I use the most significant points instead of evenly distributed 4 points.
But I don't know if that is easy to implement with possible with Douglas-Pecker.
As a side note I have not succeeded to get ST_SimplifyVW as fast as ST_Simplify. ST_Simplify I think is very impressive when it comes to speed.
/Nicklas
Sent from my Cat® phone.
Den 4 apr 2015 23:00 skrev Paul Ramsey <pramsey at cleverelephant.ca>:
> I think we should probably move the Simplify behavior to return minimum values for dimensions, start-end lines, start-middle-middle-end polygons, etc.
> http://postgis.net
> http://cleverelephant.ca
> On April 4, 2015 at 2:00:12 PM, Nicklas Avén (nicklas.aven at jordogskog.no) wrote:
> > Hallo
> > When adding tests to ST_SimplifyVW (the Visvalingam-Whyatt version of
> > simplify) I noticed some differences in behavior between ST_Simplify and
> > ST_SimplifyVW. Since the ST_Simplify behavior somewhat strange I want to
> > discuss it before I copy that behavior to ST_SimplifyVW.
> > It is discussied in many tickets, and I haven't taken the time to read
> > them all. But I think #1698 comes closest to a solution
> > http://trac.osgeo.org/postgis/ticket/1698
> > First an inconsistency with ST_Simplify that I don't understand if is
> > intentional:
> > in regression test nr 9 it shows that a polygon collapses and returns
> > nothing:
> > http://trac.osgeo.org/postgis/browser/trunk/regress/simplify_expected
> > But if you take the last test, nr 12 and change last parameter to 200 so
> > it collapses it returns an empty multipolygon.
> > SELECT '12', ST_astext(ST_Simplify('MULTIPOLYGON(((0 0, 10 0, 10 10, 0
> > 10, 0 0),(5 5, 5 6, 6 6, 8 5, 5 5)),((100 100, 100 130, 130 130, 130
> > 100, 100 100)))', 200));
> > Then from what i understand in ticket #1698 ST_Simplify is expected not
> > to remove the entire boundary but instead return something.
> > In Visvalingam-Whyatt this is the situation right now (which I am quite
> > happy with):
> > For linestrings they always return at least start and end point.
> > Polygons can collapse inner rings.
> > Boundaries is never collapsed. THey always return 4 points. That is
> > start and end point of pointarray (same point) and the two points with
> > highest effective area. So the result will be a triangle with as big
> > area as possible (not too thin triangle).
> > in multipolygons all inner rings can be collapsed but all sub-geometry
> > boundaries will remain.
> > Is there any reason to leave that concept?
> > I guess it have to be explained in doc as a difference from
> > ST_Simplify.
> > The doc now for the new functions is:
> > http://postgis.net/docs/manual-dev/ST_SetEffectiveArea.html
> > and
> > http://postgis.net/docs/manual-dev/ST_SimplifyVW.html
> > Regards
> > Nicklas
> > postgis-devel mailing list
> > postgis-devel at lists.osgeo.org
> > http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
