[postgis-devel] Collapsing behavior for simplify
Sandro Santilli
strk at keybit.net
Tue Apr 7 05:12:15 PDT 2015
On Tue, Apr 07, 2015 at 02:07:33PM +0200, Nicklas Av�n wrote:
> Ok, but when it comes to SimplifyVW I guess we don't have to care about the default to Douglas-Pecker version.
> For reference ST_SimplifyVW outputs
> POLYGON((0.5 1.5,100 200,0 200,0.5 1.5));
> from :
> SELECTST_AsText(ST_SimplifyV('POLYGON((0.5 1.5,1.5 1.5,2.5 2.5,4.5 4,100 200,0 200,-0.5 5.5,0 3.5,0.5 1.5))'::geometry, 1000));
> Javier, do you get the same from your version (with very high last parameter)?
> strk
> Is it implemented with most significant or evenly distributed 4 points?
Should be most significant (greatest distance) but Javier should probably
know more about it by now.
--strk;
