[postgis-devel] Is errorIfGeometryCollection necessary forrelate ops?
Brian M Hamlin
maplabs at light42.com
Mon Apr 13 13:43:14 PDT 2015
Hi Martin -
Is it always better to have a single MultiPoly? my naive thoughts
are a) single polys are computationally faster, and b) the raison'detre
of Multipolys is the "hole" , which could never be in a product of
otherwise independent single polys..
I admit this email is off-the-cuff so there could be something I am
not thinking about at all.. there it is though.. option to combine ?
never combine ?
very best regards from Berkeley, California
-Brian
On Mon, 13 Apr 2015 09:42:40 -0700, Martin Davis wrote:
On Mon, Apr 13, 2015 at 12:59 AM, Sandro Santilli wrote:
On Fri, Apr 10, 2015 at 10:40:32AM -0700, Martin Davis wrote:
> re what is happening in Shapely with relate on GeometryCollections:
> In fact, homogeneous GeometryCollections of Points and LineStrings can be
> trivially converted to MultiPoints and MultiLineStrings. Is is possible
> that Shapely is doing this automatically?
> Handling homogeneous GCs would be a nice enhancement for JTS & GEOS....
There's actually a ST_CollectionHomogenize function in PostGIS that
can be used to do just that.
I'm starting to think about adding a "flatten" method to JTS that would
do all the heavy lifting to transform an arbitrary GeometryCollection
into something suitable for using with relate. In addition to
converting homogenous collections into the appropriate Multi-type, it
would union all polygons to make them into a valid MultiPolygon.
postgis-devel mailing list
postgis-devel at lists.osgeo.org
http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
Brian M Hamlin
OSGeo California Chapter
blog.light42.com
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20150413/11b7c55f/attachment.html>
