[postgis-devel] For PostGIS 2.2 moving forward make liblwgeom compatible between micro releases
a.furieri at lqt.it
a.furieri at lqt.it
Mon Aug 3 12:23:18 PDT 2015
On Mon, 3 Aug 2015 13:30:10 -0400, Paragon Corporation wrote:
> Isn't ST_MakeValid, ST_Segmentize, and ST_Node inherited from GEOS?
Hi Regina,
unhappily reality is a little bit more complex than this:
- MakeValid do actually depends on GEOS; anyway the complete
implementation of MakeValid requires about thousand lines
of C code provided by liblwgeom itself.
(lwgeom_geos_clean.c source)
- more or less the same is for Node and Split: both them depend
someway on GEOS, anyway liblwgeom adds some further thousand
lines of supporting C code.
(lwgeom_geos_node.c and lwgeom_geos_split.c sources)
- Segmentize / Desegmentize does not depend at all on GEOS; all
this stuff is internally implemented in liblwgeom, and exactly
by the lwsegmentize.c source (800+ C lines)
> So I fail to see the usefulness of having to go thru liblwgeom
> instead of using
> these directly via GEOS unless GEOS becomes liblwgeom (and then we
> are back
> to where we were)
GEOS alone can't directly support this kind of "advanced" operations;
liblwgeom introduces a further added value, and such an added value
isn't at all marginal because it effectively consists in several
thousands lines of well established and thoroughly tested code.
so a real problem surely exists.
bye Sandro
