[postgis-devel] Changing ST_Expand(geometry) to return LINESTRING
Paul Ramsey
pramsey at cleverelephant.ca
Thu Feb 26 05:02:01 PST 2015
I’m OK w/ a linestring. The type is just because I need something that is a geometry to hold what I care about, which is the actual box in the header. I think most people understand the “box” idea pretty well, but n-d boxes (particular in the geography case) can be just as confusing in their own right.
P.
Paul Ramsey
http://cleverelephant.ca
http://postgis.net
On February 26, 2015 at 4:30:52 AM, Sandro Santilli (strk at keybit.net) wrote:
I was looking for a way to expand a 4D point to use the resulting
"nd-box" in an ND overlap query (&&&) and found the closest function
to do that being ST_Expand(geometry).
That function reurns a geometry of type POLYGON, but I'm thinking..
what's the POLYGON representation for a 3D or 4D box ?
Having 5 vertices makes it completely arbitrary where to put
the MIN and the MAX values of each ordinate.
Wouldn't it be less confusing to return a 2-vertices LINESTRING
instead ?
As noted in http://trac.osgeo.org/postgis/ticket/1329
a 2-vertices LINESTRING might be the closest thing to
an even less confusing "BOXND" type. It has a direction
(contrary to a MULTIPOINT) that makes it clear what the
min and max are (first and last points).
Or would you prefer to have a new "BOX" geometry type ?
Or even a new "BOXND" PostgreSQL type ?
--strk;
postgis-devel mailing list
postgis-devel at lists.osgeo.org
http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20150226/1a9325e2/attachment.html>
