[postgis-devel] Not receiving SRID conflict error
Bborie Park dustymugs at gmail.com
Fri Jan 16 08:14:09 PST 2015
Do you have a spatial index on IGBP_2012?
The only thing I can think of is that dasymetric.us_dem_prj has a spatial
index and since ST_Intersects() uses the spatial index first, there is no
rows to consider in ST_Intersects and ST_Clip.
-bborie
On Fri, Jan 16, 2015 at 7:56 AM, David Haynes II <dahaynes at umn.edu> wrote:
> Hello,
> I have a question about an error I am not receiving when I believe I
> should.
> Below are three datasets that with their SRID
> igbp_2012 (6842), us_dem_prj (3410), and us_states (4326).
> When I run a query determining the SRID for these datasets in PostgreSQL
> they confirm their SRIDs
> select st_srid(r.rast), st_srid(p.geom) from dasymetric.us_dem_prj r,
> dasymetric.us_states p limit 5
> When I run the next query, I do not receive an error, but no records are
> returned. The raster is in 3410 and the states geom column is in 4326
> SELECT state_label, ST_Clip(r.rast,p.geom) as rast FROM
> dasymetric.us_states p inner join dasymetric.us_dem_prj r on
> ST_Intersects(p.geom, r.rast) WHERE p.state_label = 'Minnesota'
> However, If I adjust the raster dataset to IGBP_2012, the error
> ERROR: Raster and geometry do not have the same SRID, shows up.
> Why am I not receiving a conflict projection error for a raster in 3410
> and a geometry in 4326? Any idea why that is occurring?
> David Haynes, Ph.D.
> Research Associate Terra Populus
> Minnesota Population Center
> www.terrapop.org
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20150116/40b37cb6/attachment.html>
