[postgis-devel] Interrupt Test considered Harmful
Sandro Santilli strk at keybit.net
Wed Jul 29 15:38:50 PDT 2015
On Wed, Jul 22, 2015 at 08:34:33AM -0700, Paul Ramsey wrote:
> I’m going to move the interrupt test out of the main ‘check’ path, so that continuous integration will stop providing so many false positives. I’m getting close to ignoring debbie now because every second commit tosses an error, either from interrupt or because of one of failed cleanup issues that seems to randomly happen. CI is only useful if it’s actually returning good results, otherwise it’s just spam and gets treated as such.
> Anyways: moving interrupt out of ‘check’ into ‘checkall’ or something
Pity, but I understand the problem.
It would be nice to be able to use CPU time rather than wall time
for checking that the interruption happens at "predictable" time,
maybe you know of an SQL-exposed function to fetch that time ?
(spent on the backend, not frontend).
--strk;
