[postgis-devel] I want to add an algorithem into postgis
xschen
xschen at clustertech.com
Fri Jul 31 16:19:15 PDT 2015
hello, every one.
I am a user of postgis, and found postgis is very slow when running
st_intersects, st_within st_contains functions on a polygon which
contents many vertex , even has gist index on geometry.
for example: polygon A,B has ten thousands points, A is very big, B is
very small, and B is in the center of A. that is very easy to know B
inside A, but postgis spends sevel seconds to calculate the
st_intersects(A,B).
I found the intersects algorithem like this:
bool intersects(geometry g1, geometry g2){
if(!g1.getEnvelope().intersects(g2.getEnvelope())){
return false;
}else{
//calculate its details
I have an ideal to improve its performance, by calculating the
intersects between the biggest inner circle of two geometry:
if( !g1.getEnvelope().intersects(g2.getEnvelope() ){
return false;
}else{
if(g1.getInnerCircle().intersects(g2.getInnerCircle() ){ //
"getInnerCircle()" returns the biggest circle inside the polygon
return true;
}else{
each point belong to inner cricle, also belong to polygon. if inner
circles intersect , polygons will intersect
to judge circles intersect is very fast, so that, my algorithem can
improve its performance.
besides, I have an amazing method to calculate the "biggest inner
circle" of an polygon very fast , by using a complex function "magic".
the method is too diffcult to explain in email.
I am just begining to develop the postgis. I dont know its architecture,
and I am solo.
would someone please guide me? introduce the architecture of postgis.
