[postgis-devel] Distance operator in presence of M
Paul Ramsey pramsey at cleverelephant.ca
Thu Jun 4 11:00:41 PDT 2015
Yes, I’d cry, because then KNN won’t work. You’d have to also figure out how to implement a closest approach model that works on index keys, such that the closest-approach distance between two keys was always less than the same distance between two actual objects.
http://postgis.net
http://cleverelephant.ca
On June 4, 2015 at 10:58:48 AM, Sandro Santilli (strk at keybit.net) wrote:
Would you cry if it did distance at closest-point-of-approach in presence
of M in both operands ? At least it'd be a meaningful one, even if not
necessarely what the user (who can always drop the M from an operand) want.
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20150604/94421c98/attachment.html>
