[postgis-devel] Public Raster C API
Nathaniel Clay
clay.nathaniel at gmail.com
Sun Jun 7 21:40:29 PDT 2015
Hi All,
I've followed strk's suggestion and used the lwgeom library as an example
but I seem to have created a shared library with no symbols in the library.
Please find attached the Makefile.in and the x64 library it creates.
On Fri, May 29, 2015 at 7:34 AM, Nathaiel Clay <clay.nathaniel at gmail.com>
wrote:
> Brian,
> postgis_trunk/raster/scripts/python/raster2pgsql.py is there for
> historical reference, it was rewritten in c.
> Thanks,
> Nathaniel Hunter Clay
> *From:* Brian M Hamlin [mailto:maplabs at light42.com]
> *Sent:* Friday, May 29, 2015 1:49 AM
> *To:* PostGIS Development Discussion; Nathaniel Clay
> *Subject:* Re: Public Raster C API
> I recall long ago I was interested in seperating GEOS 'make valid' into
> a library..
> I do not see a Shapely method for 'make valid', on quick inspection..
> at any rate, to seperate out librtcore.so from rtpostgis.so
> in configure.ac line around line #1274
> I see some lwgeom references...
> where else to look for lwgeom config files as an example ?
> ps- I am looking at
> it uses the gdal python bindings.. no indication of linking to
> rtpostgis-2.2.so
> -dbb
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20150608/3ac50b94/attachment.html>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20150608/3ac50b94/attachment.so>
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20150608/3ac50b94/attachment.obj>
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20150608/3ac50b94/attachment-0001.obj>
