[postgis-devel] Distance operator in presence of M
Sandro Santilli
strk at keybit.net
Mon Jun 8 04:39:12 PDT 2015
On Sat, Jun 06, 2015 at 02:32:22AM +0200, HÃ¥vard Tveite wrote:
> To be able to do distance calculations on data with M
> values, we need to be able to transform the M value into
> a "compatible" dimension (resulting in a Euclidean space).
> When M is time, this transform could be based on a
> user-specified velocity (d=v*t). In general, a
> user-specified function (as suggested by Greg) that does
> this transformation would be useful. Or perhaps some
> pre-defined functions with user-specified parameters
> could work (d=a*M).
I was thinking we should just allow scaling M with the
existing ST_Scale function. That should do, right ?
See https://trac.osgeo.org/postgis/ticket/3062
--strk;
