[postgis-devel] EMPTY is as EMPTY does?
Paul Ramsey
pramsey at cleverelephant.ca
Wed Jun 24 12:59:19 PDT 2015
Yes, it should be safe at an app level. I ran into the case though, because we had a query that was bringing down one server, but couldn’t be replicated on others… why? because when we tried to move the data to a test server it had to go through dump/restore which effectively removed the case (MULTILINESTRING(EMPTY,EMPTY)) that was causing the crash. So it’s a problem of correctness in that we cannot replicate a database exactly using dump/restore. Of course, we already have that in one case (POINT EMPTY) but maybe we don’t want to deliberately have it for other cases too.
ATB,
P
http://postgis.net
http://cleverelephant.ca
On June 24, 2015 at 12:55:53 PM, Sandro Santilli (strk at keybit.net) wrote:
Which constraint would that fail ? Your example above has a MULTILINESTRING
in and a MULTILINESTRING out, sounds "safe" (although struct-breaking).
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20150624/ad7aae32/attachment.html>
