[postgis-devel] Unknown coord_dimension in geometry_columns
Sandro Santilli
strk at keybit.net
Tue Mar 3 07:33:52 PST 2015
On Tue, Mar 03, 2015 at 04:20:19PM +0100, Rémi Cura wrote:
> Don't you need a primary key or equivalent for QGIS?
Only if you want to edit.
I know the problem is about coord_dimension because I see QGIS WKB parser
erroring out due to higher dimension flags not being recognized. The QGIS
code does not invoke ST_Force2D on those values because it thinks they
are 2d already (as false-advertised by geometry_columns).
--strk;
