[postgis-devel] 2.2 Discussion (a)
Nicklas Avén
nicklas.aven at jordogskog.no
Fri May 1 13:37:16 PDT 2015
I marked 2 tickets as high
#3085 is about lacking support for reading aggregated twkb. Things will
happen there quite soon I think. Paul is involved in that.
#2034 about mixed input dimensionality in ST_3DClosesPoint. There is so
many discussions spread over many tickets so I have to take some time to
read it to understand what I shall do. If someone knows the right
answer, please tell me and I will do it.
About ST_SimlifyVW I have considered that finished.
About twkb in general work is in progress. As mentioned Paul is also on
it and we should have stable and good solution in not to long time.
Best Regards
Nicklas Avén
On Thu, 2015-04-30 at 18:06 -0400, Paragon Corporation wrote:
> Okay I marked the ones I think I can get done as high or blocker. Here is
> our much shorter list:
> http://trac.osgeo.org/postgis/query?priority=high&priority=blocker&status=as
> signed&status=new&status=reopened&milestone=PostGIS+2.2.0&order=priority&rep
> ort=28
> Relisted here-- at cursory glance -- I'm not seeing any of Nicklas stuff
> (Nicklas I know you have some stuff brewing almost done but not completely
> finished so mark them up), Also not seeing the sfcgal patch.
> #2305 Document sfcgal functions and amendment notes for existing
> colivier
> #2914 [raster] ST_Rescale: Could not create GDAL transformation
> object for output dataset creation dustymugs
> #3096 PostgreSQL 9.5 regress failure raster dustymugs (I need
> to recheck this one, may not be an issue anymore)
> #1024 Change 3D relationship functions to use &&& in addition to
> && pramsey
> #1847 spgist 2d bindings for geometry pramsey
> #2263 [raster] Audit usage of serialize/deserialize vs wkb/hexwkb
> dustymugs
> #2283 shp2pgsql may be parsing shp's multipolygon incorrectly
> mcayland
> #2287 --enable-debug builds are way too verbose pramsey
> #2316 Setup buildbot jobs to test sfcgal robe
> #2358 Add post-check phase to PostGIS build (installcheck) strk
> #2400 Add more documentation about address_standardizer extension
> robe
> #2422 geography regression difference ST_DWithin pramsey
> #2459 Speed up pagc_normalize_address robe
> #2717 st_numPoints, st_PointN, st_startPoint and st_endPoint full
> support on curved geoms pramsey
> #2734 TIGER geocoder gives no results with omitted zipcode robe
> #2737 [PATCH] Upgrade of spatial_ref_sys.sql to EPSG v8.5 robe
> #2816 Create data extension for address_standardizer woobri
> #2838 Finish up X3D implementation for all types robe
> #2840 Support X3D Geospatial Component in ST_AsX3D function robe
> #2867 Can't upgrade sfcgal extension robe
> #2877 Revise configure to build make scripts for
> address_standardizer extension robe
> #2906 Update to work with tiger 2014 data robe
> #2980 directional as a street name should not be abbreviated robe
> #2981 standardize address returns no answer for particular highway
> woobri
> Thanks,
> Regina
> -----Original Message-----
> From: postgis-devel-bounces at lists.osgeo.org
> [mailto:postgis-devel-bounces at lists.osgeo.org] On Behalf Of Paul Ramsey
> Sent: Thursday, April 30, 2015 2:09 PM
> To: PostGIS Development Discussion
> Subject: [postgis-devel] 2.2 Discussion (a)
> Hey devs,
> I'd like to talk through getting 2.2 out in a reasonable time frame, that
> means
> (a) identifying the major pieces of work we individually hope to have in the
> release
> (b) agreeing on a feature freeze date
> (c) committing to work our particular ticket lists, triaging in particular
> and closing what can be closed
> Can we start with (a) today: what pieces of development do you hope to
> include in 2.2?
> Thanks,
> P.
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
