[postgis-devel] Wrong answer from new knn with recheck
Nicklas Avén nicklas.aven at jordogskog.no
Sat May 23 22:02:19 PDT 2015
Then i gives the right answer.
/Nicklas
Sent from my Cat® phone.
Den 24 maj 2015 01:57 skrev Paul Ramsey <pramsey at cleverelephant.ca>:
> What happens when you run the query using the suspect house as a literal instead of doing the fun lateral query?
> P.
> http://postgis.net
> http://cleverelephant.ca
> On May 23, 2015 at 1:36:55 PM, Nicklas Avén (nicklas.aven at jordogskog.no) wrote:
> > Since I cannot reach trac I post it here.
> > I have been playing some with latest trunk and latest postgresql.
> > Since I cannot reach trac I cannot check that it is absolute latest
> > trunk but I have r13544
> > PostgreSQL I pulled from git yesterday.
> > I have 2 data sets. one with roads and one with houses.
> > Attached is data that reproduces the problem.
> > table r is the roads and table t is the houses.
> > If I then run this query:
> > SELECT t.navn, r.gid, st_distance(r.geom, t.geom)
> > FROM t CROSS JOIN LATERAL
> > (SELECT r.gid, r.geom FROM r ORDER BY t.geom <->r.geom LIMIT 2) r;
> > I get this result:
> > navn | gid | st_distance
> > Gramstad | 988075 | 90.2225986190226
> > Gramstad | 986169 | 128.356279805393
> > Sidhusgohpi | 982379 | 1379790.96016902
> > Sidhusgohpi | 1724598 | 27839.424840718
> > What is totally wrong here is the third row. That road is 1379 km away.
> > The last row gives the right answer. The closest road to that house is
> > 27 km away.
> > With the full data sets I can play with the limit and see how roads from
> > the first house in some way is following to the second house. road nr
> > 982379 is just 215 meters away from house nr 1. So something is not
> > letting go.
> > Thanks
> > Nicklas Avén
> > postgis-devel mailing list
> > postgis-devel at lists.osgeo.org
> > http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
