[postgis-devel] is PostGIS ready for git ?
    'Sandro Santilli'
    strk at keybit.net
    Tue Oct 13 01:40:32 PDT 2015
NOTE: things are moving on the trac/git integration, you can
follow it here: https://trac.osgeo.org/osgeo/ticket/720
If you want to join the tests, file a ticket on the sandbox
project and request to be added to the group:
https://trac.osgeo.org/gittest
--strk;
On Mon, Oct 12, 2015 at 03:36:57PM +0200, 'Sandro Santilli' wrote:
> On Mon, Oct 12, 2015 at 08:56:28AM -0400, Paragon Corporation wrote:
> > My main issue with git was losing trac, but if we can have trac and git I'd
> > be fine with that.
> I'm talking with Martin Spott about taking a step forward about that,
> they are using trac with git here: https://trac.osgeo.org/martin/
> take a look.
> If you want to join, we're in #telascience IRC channel on freenode.
> I believe you've done trac database massaging in the past, get ready
> because your ninja skills will be needed to convert all "r1234"
> references to "changeset:deadbeef", to keep cross references in sync
> (see https://lists.osgeo.org/pipermail/discuss/2015-October/015106.html)
> --strk;
> > -----Original Message-----
> > From: Sandro Santilli [mailto:sandro.santilli at gmail.com] On Behalf Of Sandro
> > Santilli
> > Sent: Monday, October 12, 2015 5:42 AM
> > To: postgis-devel at lists.osgeo.org
> > Cc: Paragon Corporation <lr at pcorp.us>; Paul Ramsey
> > <pramsey at cleverelephant.ca>; Bborie Park <dustymugs at gmail.com>; Mark
> > Cave-Ayland <mark.cave-ayland at ilande.co.uk>
> > Subject: is PostGIS ready for git ?
> > Devs, how comfortable are you with git nowadays ?
> > Would moving the PostGIS code repository to git present any trouble for
> > current contributors ? Or would it be mostly welcome ?
> > My list of troubles for moving to git are:
> >   1. Current OSGeo TRAC installation does not yet include support
> >      for git: https://trac.osgeo.org/osgeo/ticket/720
> >   2. We don't have a recipe yet to update our ChangeLog file in a
> >      compatible way
> > Anything else ?
> > --strk;
