[postgis-devel] SRS Magic
Even Rouault
even.rouault at spatialys.com
Thu Oct 29 10:22:08 PDT 2015
Le jeudi 29 octobre 2015 17:23:14, Paul Ramsey a écrit :
> One of the constant requests to make postgis easier to use is SRID
> detection. At this point GDAL has almost all the bits and pieces to do
> SRID detection from PRJ inputs.
Paul,
if by PRJ, you mean ESRI Shapefile .prj files whose WKT definition strips off the
EPSG code even when the WKT is derived from an EPSG definition, then indeed
there's some magic to add in GDAL to guess the EPSG code. There's a
AutoIdentifyEPSG() method (
http://www.gdal.org/classOGRSpatialReference.html#acb0373c83927bfd694048da6f79e33ea
) but it is fairly limited.
Even
http://www.spatialys.com
