[postgis-devel] postgis extension sans raster (only for folks who can't compile with raster support) - PSC Vote and developer/packager comments please
Pierre Racine
Pierre.Racine at sbf.ulaval.ca
Fri Oct 30 08:47:47 PDT 2015
I think Even`s comment was skipped too fast. If GDAL has no dependency on QT and the problem comes from the fact they compile it with QT then THEY should fix the way they compile GDAL instead of having many projects based on GDAL to adapt to their particular situation.
I would investigate further on their side before doing a major step that takes PostGIS years behind before going further with anything proposed in this thread.
My two cents.
Pierre
________________________________________
From: postgis-devel <postgis-devel-bounces at lists.osgeo.org> on behalf of Even Rouault <even.rouault at spatialys.com>
Sent: Sunday, October 25, 2015 4:09 AM
To: postgis-devel at lists.osgeo.org
Subject: Re: [postgis-devel] postgis extension sans raster (only for folks who can't compile with raster support) - PSC Vote and developer/packager comments please
> The issue is as I understand it is he doesn't package GDAL so he gets it
> from upstream and upstream GDAL compiles in QT to support other GFOSS.
I don't get the relationship between GDAL and QT. GDAL has for sure no direct
dependency to QT. And I can't think of a GDAL dependency library that would
link to QT libs.
http://www.spatialys.com
postgis-devel mailing list
http://lists.osgeo.org/mailman/listinfo/postgis-devel
