[postgis-devel] SFCGAL version requirements?
Paul Ramsey
pramsey at cleverelephant.ca
Wed Aug 3 06:55:37 PDT 2016
Right, it will build OK, but you'll be missing some functions. I see tests
for
POSTGIS_SFCGAL_VERSION
in the code. So if I build against 1.3 and then deploy against 1.2 I'll
have symbols missing, as in the question. I guess this is a packager
problem really, someone built against 1.3 but didn't declare a tight
version dependency.
P.
On Wed, Aug 3, 2016 at 6:27 AM, Sebastiaan Couwenberg <sebastic at xs4all.nl>
wrote:
> On 08/03/2016 03:19 PM, Paul Ramsey wrote:
> > Regarding this stackexchange question:
> https://gis.stackexchange.com/questions/204575/libsfcgal-so-1-undefined-symbol-upgrading-to-postgis-2-2-2
> > Is it possible that PostGIS 2.2 requires SFCGAL 1.3? If so, our configure
> > script should be doing a version test, but I don't see that happening in
> > the configure.ac.
> I don't think so, OSGeo-Live built PostGIS 2.2.2 with SFCGAL 1.2.2
> without issue.
> Kind Regards,
> Bas
> GPG Key ID: 4096R/6750F10AE88D4AF1
> Fingerprint: 8182 DE41 7056 408D 6146 50D1 6750 F10A E88D 4AF1
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20160803/d1620227/attachment.html>
