[postgis-devel] A snap for PostGis
Julia Palandri
julia.palandri at canonical.com
Fri Dec 9 06:37:43 PST 2016
Hi again,
I was wondering if there are other questions I might be able to help with?
Maybe somebody even started playing with snapcraft and has any doubts? Let
me know in either case :)
Best,
On Fri, Dec 2, 2016 at 5:06 PM, Julia Palandri <julia.palandri at canonical.com
> wrote:
> Hi,
> On Tue, Nov 29, 2016 at 1:10 PM Darafei "Komяpa" Praliaskouski <
> me at komzpa.net> wrote:
>> At the moment there are different snaps for each major version available
>> (snap find postgres shows this), all of these in the stable channel. We
>> are, however, working towards having smarter channels. Right now there is
>> edge, which you can update with every commit to trunk. There's also beta,
>> candidate, and of course stable.
>> We're aiming at having 9.6/stable, 9.6/candidate, 9.6/beta, 9.6/edge,
>> 9.5/stable, 9.5/candidate, and so on, and also a "magic" latest family:
>> latest/edge, latest/beta, etc. latest'stable would be the version you get
>> when you ask the system to install any snap, without manually specifying
>> the major version and flavour.
>> This describes install, but not upgrade process.
> Well, rather, I was trying to explain that with different "series" for
> each major version, updates should be handled ok.
>> If you upgrade by just replacing binaries, you should keep in mind
>> postgres 9.6 can't work with database created in postgres 9.4 - so, you
>> need pg_upgrade (+ several manual steps) to perform the upgrade.
> Right. So, I've been talking with the people that has been helping with
> the postgres snap, and they told that maybe the content interface might be
> able to give a hand for plupgrades between major versions.
>> If you install postgis, you have a postgis binary for each version of
>> postgis for each version of postgres. After you connect to postgres
>> database, you can switch the version of extension used, and several running
>> simultaneous queries can be using different versions of postgis.
>> Packaging postgis+postgres in single package has a disadvantage - you
>> can't use more than two extensions at the same time in that scheme.
>> How is it going to be handled?
> Right, so maybe the solution would be to create a pg interface. Or again,
> we could use the content interface to create a way for extensions to be
> placed where PG can find them. This might need some coordinated work with Command
> Prompt to get the PG snap to look for extensions there. If you're
> interested in investing some time into it, so are we :) We are writing to
> upstreams also to know what they need (even though we can't promise it will
> be ready soon), but knowing what's lacking to snaps for it to be adopted
> certainly can modify our roadmap.
> Again, if interested, we might be able to coordinate a meeting with other
> people involved to try to find a way :)
> Best,
> Julia
Julia
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20161209/d9d168e0/attachment.html>
