[postgis-devel] Validity flag
Oliver Courtin
olivier.courtin at oslandia.com
Mon Feb 29 05:15:24 PST 2016
Le 29 févr. 2016 à 14:00, Sandro Santilli a écrit :
> On Mon, Feb 29, 2016 at 12:45:38PM +0100, Oliver Courtin wrote:
>> With only the _valid_ one , if we are sure that geometry is valid,
>> we could skip the check validity in SFCGAL (or other backend),
>> and if we not sure (i.e unknown or not valid),
>> we have to do the check validity backend side.
> Why check if it's already checked and invalid ?
> You could just say it's invalid, right away, and
> suggest to use ST_MakeValid.
> BTW, ST_MakeValid checks for validity as its first thing,
> making it slow when the input is already known as being
> invalid. It would then also benefit from knowing _invalid_
> from the start.
> And ST_Simplify (for example) could set _invalid_ flag when
> returning collapsed lines (structurally invalid).
I understand what you mean, Sandro, but:
- We don't have that much flags still available
- On userland indeed we allow invalid geometry to be stored,
but only with the ST_MakeValid stuff, or equivalent, in mind.
I can't figure a reason to encourage keeping invalid data on a long term.
O.
