[postgis-devel] [postgis-tickets] r14592 - Patch from Sebastiaan Couwenberg to fix test_wkb_out_point failure on hppa & mips.
Regina Obe lr at pcorp.us
Tue Jan 12 22:45:07 PST 2016
Greg,
I committed to both trunk and branch 2.2.  I blindly trusted Sebastian's
judgement on things since it was just a regression test (not code change),
he had tested on platforms I have no access to,
and the tests still passed under my mingw64 install.  I'm not knowledgeable
enough in C to judge code.
Perhaps Paul , Sandro, or others can chime in on this.
Thanks,
Regina
-----Original Message-----
Sent: Tuesday, January 12, 2016 7:44 PM
To: Regina Obe <lr at pcorp.us>
Cc: postgis-devel at lists.osgeo.org
Subject: Re: [postgis-tickets] r14592 - Patch from Sebastiaan Couwenberg to
Regina Obe <lr at pcorp.us> writes:
> Author: robe
> Date: 2016-01-12 16:36:35 -0800 (Tue, 12 Jan 2016) New Revision: 14592
> Modified:
>    branches/2.2/liblwgeom/cunit/cu_out_wkb.c
> Log:
& mips.
> references #3426
I'm a little surprised at changes going onto the release branch without
first being on trunk and having review and then getting cherrypicked onto
the release branch.
> +/* parisc and mips (at least some processors) have a different nan
> +representation from other arches. */ #if !defined(__hppa__) &&
> +!defined(__mips__) # define nan_val( v1, v2)  v1 #else # define
> +nan_val( v1, v2)  v2 #endif
This seems quite awkward.  It would seem the tests should be grounded in the
standards (presumably postgis requires IEEE754 to start and doesn't work on
the vax :-).  Isn't there some way to start with a nan expressed as a
double, and then to convert that to a sql representation?  Or to write an
"isnan_wkb" function that takes the string/hex representation, extracts a
double, and then uses the C99-specified isnan(3) procedures.
Encoding of IEEE754 values into hex and having them in the tests seems
nonrobust, and it seems extra fragile to have switches by arch.
