[postgis-devel] Building Postgris on Solaris 11
Andrew Watkins andrew at dcs.bbk.ac.uk
Tue Jul 5 05:08:42 PDT 2016
Paul,
I did see that I tried it but still gave me problems.
May be I should revisit it to see if it can solve other problems.
Thanks,
Andrew
On 07/05/16 13:04, Paul Ramsey wrote:
> I should have sent this at the time, but it didn't answer your
> proximate problem since you were building w/ the Sun compiler...
> https://github.com/pramsey/suite-solaris-build/blob/master/pgsql-postgis-gdal-build.sh
> P.
> On Tue, Jul 5, 2016 at 4:29 AM, Andrew Watkins <andrew at dcs.bbk.ac.uk> wrote:
>> On 06/30/16 16:28, Andrew Watkins wrote:
>> Hello folks,
>> Beening battling my way through Postgis on Solaris and I am getting close
>> but still getting errors. Here is the relevant information and any pointers:
>> postgis-2.2.2# ./configure CC=/opt/studio12u1/bin/cc CFLAGS="-m64
>> -DNAN=\"(0.0/0.0)\"" CPPFLAGS=-m64 CXXFLAGS=-m64 LDFLAGS="-m64
>> -L/usr/local/postgres/pgdg/lib/64 -L/usr/local/postgres/geos/lib
>> -L/usr/local/postgres/proj4/lib" \
>>      --with-pgconfig=/usr/local/postgres/pgdg/bin/64/pg_config \
>>      --with-geosconfig=/usr/local/postgres/geos/bin/geos-config \
>>      --with-gdalconfig=/usr/local/postgres/gdal/bin/gdal-config \
>>      --with-projdir=/usr/local/postgres/proj4
>>    PostGIS is now configured for i386-pc-solaris2.11
>>   -------------- Compiler Info -------------
>>    C compiler:           /opt/studio12u1/bin/cc -m64 -DNAN="(0.0/0.0)"
>>    SQL preprocessor:     /usr/gcc/4.5/bin/cpp -traditional-cpp -w -P
>>   -------------- Dependencies --------------
>>    GEOS config:          /usr/local/postgres/geos/bin/geos-config
>>    GEOS version:         3.5.0
>>    GDAL config:          /usr/local/postgres/gdal/bin/gdal-config
>>    GDAL version:         2.1.0
>>    PostgreSQL config:    /usr/local/postgres/pgdg/bin/64/pg_config
>>    PostgreSQL version:   PostgreSQL 9.5.3
>>    PROJ4 version:        49
>>    Libxml2 config:       /usr/bin/xml2-config
>>    Libxml2 version:      2.9.2
>>    JSON-C support:       yes
>>    PCRE support:         no
>>    PostGIS debug level:  0
>>    Perl:                 /usr/bin/perl
>>   --------------- Extensions ---------------
>>    PostGIS Raster:       enabled
>>    PostGIS Topology:     enabled
>>    SFCGAL support:       disabled
>>    Address Standardizer support:       disabled
>>   -------- Documentation Generation --------
>>    xsltproc:             /usr/bin/xsltproc
>>    xsl style sheets:
>>    dblatex:
>>    convert:
>>    mathml2.dtd:          http://www.w3.org/Math/DTD/mathml2/mathml2.dtd
>> # make
>> /usr/bin/perl ../utils/postgis_proc_set_search_path.pl postgis.sql UNUSED >
>> postgis_proc_set_search_path.sql
>> /usr/gcc/4.5/bin/cpp -traditional-cpp -w -P -I../libpgcommon legacy.sql.in |
>> grep -v '^#' | \
>> /usr/bin/perl -lpe "s'MODULE_PATHNAME'\$libdir/postgis-2.2'g" > legacy.sql
>> /usr/bin/perl ../utils/create_undef.pl legacy.sql 95 > uninstall_legacy.sql
>> legacy_minimal.sql.in | grep -v '^#' | \
>> legacy_minimal.sql
>> legacy_gist.sql.in | grep -v '^#' | \
>> legacy_gist.sql
>> make[1]: Leaving directory `/tmp/postgis-2.2.2/postgis'
>> ---- Making all in regress
>> make[1]: Entering directory `/tmp/postgis-2.2.2/regress'
>> make[1]: Nothing to be done for `all'.
>> make[1]: Leaving directory `/tmp/postgis-2.2.2/regress'
>> ---- Making all in raster
>> make[1]: Entering directory `/tmp/postgis-2.2.2/raster'
>> make -C rt_core
>> make[2]: Entering directory `/tmp/postgis-2.2.2/raster/rt_core'
>> /opt/studio12u1/bin/cc -m64 -DNAN="(0.0/0.0)"  -KPIC -DPIC
>> -I../../liblwgeom -I/usr/local/postgres/gdal/include
>> -I/usr/local/postgres/proj4/include -I/usr/local/postgres/geos/include   -c
>> -o rt_util.o rt_util.c
>> "/usr/local/postgres/gdal/include/ogr_core.h", line 415: warning: enumerator
>> value overflows INT_MAX (2147483647)
>> "/usr/local/postgres/gdal/include/ogr_core.h", line 416: warning: enumerator
>> "/usr/local/postgres/gdal/include/ogr_core.h", line 417: warning: enumerator
>> "/usr/local/postgres/gdal/include/ogr_core.h", line 418: warning: enumerator
>> "/usr/local/postgres/gdal/include/ogr_core.h", line 419: warning: enumerator
>> "/usr/local/postgres/gdal/include/ogr_core.h", line 420: warning: enumerator
>> "/usr/local/postgres/gdal/include/ogr_core.h", line 421: warning: enumerator
>> "librtcore.h", line 151: warning: macro redefined: __attribute__
>> "librtcore.h", line 245: syntax error before or at: (
>> "librtcore.h", line 244: function cannot return function or array
>> "librtcore.h", line 245: warning: function prototype parameters must have
>> types
>> "librtcore.h", line 245: warning: syntax error:  empty declaration
>> "/usr/include/assert.h", line 23: syntax error before or at: (
>> "/usr/include/assert.h", line 23: function cannot return function or array
>> "rt_util.c", line 142: warning: statement not reached
>> "rt_util.c", line 173: warning: statement not reached
>> cc: acomp failed for rt_util.c
>> make[2]: *** [rt_util.o] Error 2
>> make[2]: Leaving directory `/tmp/postgis-2.2.2/raster/rt_core'
>> make[1]: *** [corelib] Error 2
>> make[1]: Leaving directory `/tmp/postgis-2.2.2/raster'
>> make: *** [all] Error 1
>> I have tried it with gcc but I get the same error.
>> Well, it looks like people don't use Solaris for PostGIS or they don't share
>> there findings.
>> I do like sharing here are is my blog entries for compiling PostGIS on
>> Solaris 11
>> http://notallmicrosoft.blogspot.co.uk/2016/07/install-postgis-on-solaris-11-113.html
>> Only bad news is that I have not managed to get all modules working, but it
>> is a start.
>> Anyway, hope it helps others.
>> Andrew Watkins * Birkbeck, University of London * Computer Science *
>> * http://notallmicrosoft.blogspot.com *
>> * UKOUG Systems SIG Chair *
>> * UKOUG Tech committee *
>> * tel: 020 7631 6720 *
>> postgis-devel mailing list
>> postgis-devel at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20160705/2767d5dc/attachment.html>
