[postgis-devel] postgis_tiger geocoding extension : France & temporal geocoding
Regina Obe
lr at pcorp.us
Thu Jun 16 22:30:16 PDT 2016
> On Thu, Jun 16, 2016 at 6:10 AM, Rémi Cura <remi.cura at gmail.com> wrote:
> Hey dear list,
> I'm currently considering extending postgis geocoder.
> I have two needs:
> - to work with French data
> - to perform temporal geocoding (you give an addresses and a date, you
get geographic position).
> For the moment I'm trying to understand how the geocoder works with USA
data.
> I imported Massachusetts for a test, and everything seems okay except
that my tiger.state table is empty, which prevents geocoding.
> Notwithstanding the import step, and the adress normaliser, it seems to
boil down to a large query in the function tiger.geocode_address().
> I would be delighted to have some pointers on the design of the
postgis_tiger_geocoder extension.
> In perticular, I don't understand the address standardizer business at
all (yeah, I found some doc, no, I don't understand it well)
> Many thanks for help,
> Cheers,
> Rémi-C
Just adding to what Steve has already said.
Don't try to use the postgis tiger geocoder as a model of how to set up a
geocoder.
The structure of it is very tied to how the US Census Tiger data is setup.
The irony is because it is setup like US Census, I think people try to use
it for more than a geocoder and I get bug reports on fields I ignored
because they really aren't relevant as far as geocoding is concerned or not
relevant to me (in other moneywise ways). I can't blame them since I do use
it myself on other projects for more than just geocoding. E.g. census tract
work or just joining with the states, counties etc when I need a county
list.
If I had started from scratch instead of inheriting the code this is not how
I would do it.
But without enough traction of people willing to devote time/fund a more
generic geocoder, the more globally useful solution will not go anywhere.
Thanks,
Regina
