[postgis-devel] raster2pgsql segfaults with raster data in GRASS format
Blumentrath, Stefan Stefan.Blumentrath at nina.no
Fri Jun 24 02:00:21 PDT 2016
raster2pgsql gives me some trouble with data in GRASS format.
I compiled GDAL 2.1dev with support for GRASS 7.0 and then PostGIS against that GDAL version and PostgreSQL 9.5 and raster2pgsql lists the GRASS format...
However, when I now try to load data from GRASS to PostGIS, raster2pgsql segfaults.
I tried wrapping the GRASS data in a vrt, whithout success.
After translating the GRASS file to GeoTiff, wich went well in GDAL, raster2pgsql imports the tif just fine.
So GDAL is not the reason and since I assigned a new NoData value in the vrt it is not related to this: https://trac.osgeo.org/postgis/ticket/828 either (there are actually no NoDada values in my grid)...
Anyone with an idea where to look for the error?
Cheers
Stefan
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20160624/e9fc8840/attachment.html>
