[postgis-devel] Building Postgris on Solaris 11
Sandro Santilli strk at kbt.io
Thu Jun 30 12:41:29 PDT 2016
On Thu, Jun 30, 2016 at 04:28:02PM +0100, Andrew Watkins wrote:
> Beening battling my way through Postgis on Solaris and I am getting
> close but still getting errors. Here is the relevant information and
> any pointers:
> "librtcore.h", line 151: warning: macro redefined: __attribute__
> "librtcore.h", line 245: syntax error before or at: (
> "librtcore.h", line 244: function cannot return function or array
> "librtcore.h", line 245: warning: function prototype parameters must
> have types
> "librtcore.h", line 245: warning: syntax error:  empty declaration
> I have tried it with gcc but I get the same error.
Which gcc version ?
Does removing the __attribute__ line fix it ?
If you can give me a shell and a budget I could look at
the issue directly on the target machine ...
--strk;
  ()   Free GIS & Flash consultant/developer
  /\   https://strk.kbt.io/services.html
