[postgis-devel] transifex complaining about pot files
    Sandro Santilli
    strk at keybit.net
    Sun Mar  6 11:31:29 PST 2016
Did anyone recently update the source .pot files in an incompatible way ?
Forwarding a couple of mails just received from Transifex
(dunno who else receives these mails)
----- Forwarded message from Transifex <admin at transifex.com> -----
Date: Sun, 06 Mar 2016 19:10:21 -0000
To: strk at keybit.net
Subject: [Transifex] Automatic update of the source file of introduction.xml.pot in PostGIS failed
Hi Sandro Santilli,
We have not been able to update the source file for the resource introduction.xml.pot[1] of the project PostGIS[2].
The URL we used to update the source file from was https://raw.githubusercontent.com/postgis/postgis/svn-trunk/doc/po/templates/introduction.xml.pot.
The exact error we encountered was:
'ascii' codec can't encode character u'\xe9' in position 4100: ordinal not in range(128)
[1]: https://www.transifex.com/_/resources/ajax/postgis/postgis/edit/introductionxmlpot/
[2]: https://www.transifex.com/postgis/postgis/
The Transifex Robot
https://www.transifex.com/settings/notices/
----- End forwarded message -----
Date: Sun, 06 Mar 2016 19:11:28 -0000
Subject: [Transifex] Automatic update of the source file of release_notes.xml.pot in PostGIS failed
Hi Sandro Santilli,
We have not been able to update the source file for the resource release_notes.xml.pot[1] of the project PostGIS[2].
The URL we used to update the source file from was https://raw.githubusercontent.com/postgis/postgis/svn-trunk/doc/po/templates/release_notes.xml.pot.
'ascii' codec can't encode character u'\xe9' in position 14979: ordinal not in range(128)
[1]: https://www.transifex.com/_/resources/ajax/postgis/postgis/edit/release_notesxmlpot/
The Transifex Robot
--strk;
