[postgis-devel] Fwd: Invalid Byte Sequence Error when using st_bandpath
Tumasgiu Rossini
rossini.t at gmail.com
Tue May 17 01:00:39 PDT 2016
Hello list,
I came across an error using st_bandpath,
When using PostgreSQL binary output format, executing the function on
rasters registered with UNC paths fails with error message :
"22021: invalid byte sequence for encoding « WIN1252 » : 0x00"
When using Text mode, the functions works correctly.
My guess is that the first character of a UNC path which is a
backslash is considered as an escape sequence.
But it seems you can't escape the first two backslashes when
using raster2pgsql (tried \\\\, /\/\, doublequoted path and
every combination of these three).
My configuration :
Windows 7
Postgres 9.3.5
Postgis 2.1.3
Database using WIN1252 Encoding and French_France.1252 collate.
Client encoding : UTF-8
Thank for reading.
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20160517/b84c5293/attachment.html>
