[postgis-devel] [postgis-tickets] r14916 - Correction to doc for ST_GeomFromText (it accepts SRIDs not defined in spatial_ref_sys)
Daniel Baston
dbaston at gmail.com
Wed May 25 06:52:28 PDT 2016
Good call - looks like this was broken by
https://trac.osgeo.org/postgis/ticket/3223
Should that work be reverted?
Dan
On Wed, May 25, 2016 at 8:49 AM, Sandro Santilli <strk at kbt.io> wrote:
> On Tue, May 24, 2016 at 05:49:06PM -0700, Daniel Baston wrote:
> > Author: dbaston
> > Date: 2016-05-24 17:49:06 -0700 (Tue, 24 May 2016)
> > New Revision: 14916
> > Modified:
> > trunk/doc/reference_constructor.xml
> > Log:
> spatial_ref_sys)
> Was there a change in beavior ? If so it should be documented.
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20160525/5fec6cca/attachment.html>
