[postgis-devel] please review my assumption about segmentize and bbox
Sandro Santilli strk at kbt.io
Sat Nov 12 03:12:27 PST 2016
Doing topology loading tests I found time is spent to update
the bounding box of faces whenever their edges are split.
Following the train of thougths I arrived at asking myself:
Is it possible that adding vertices in a segment could ever change
the segment bounding box ?
My answer is NO.
Could you please review and confirm ?
If my answer is correct, not only we can speed up topology loading,
but also (for example) the ST_Segmentize function, which is currently
*dropping* a cached BBOX value to be on the safe side (ie: to not
answer that question).
Math proofs welcome :)
--strk;
