[postgis-devel] PostGIS 2.2.3 is released
Regina Obe lr at pcorp.us
Thu Oct 6 08:55:00 PDT 2016
The PostGIS development team is pleased to announce the release of PostGIS
2.2.3.
As befits a patch release, the focus is on bugs and breakages.
Source download:
http://download.osgeo.org/postgis/source/postgis-2.2.3.tar.gz
HTML Doc download:
http://download.osgeo.org/postgis/docs/doc-html-2.2.3.tar.gz
PDF doc download: http://download.osgeo.org/postgis/docs/postgis-2.2.3.pdf
ChangeLog: https://svn.osgeo.org/postgis/tags/2.2.3/ChangeLog
Bug Fixes and Improvements
    3615, Fix schema support in RT_CreateOveriew (Cait Smith)
    3628, Fix lack of support for capitalized-Y in SwapOrdinates
    3524, Add interruptibility to geography brute-force distance calculation
    3522, Handle POINT and MULTIPOINT correctly in ST_Subdivide
    3565, ST_SetPoint can crash backend
    3571, Install desktop file and application icons for shp2pgsql-gui
(Sebastiaan Couwenberg)
    3573, Operator <<->> incorrectly calculates m distance
    3579, Crash in LWGEOM2GEOS
    3515, tiger_data not being backed up
    3569, Incorrect coordinates returned by ST_CollectionHomogenize (Dan
Baston)
    3602, perl as found by configure is not used in tiger extension,
postgis_sfcgal, address_standardizer
    3604, pgcommon/Makefile.in orders CFLAGS leads to installed liblwgeom.h
(Greg Troxel)
    3607, Fix inconsistency with multilinestring in
ST_LocateBetweenElevations (Artur Zakirov)
    3608, Fix crash passing -W UTF-8 to shp2pgsql (Matt Amos)
    3624, [raster] load_outdb related tests fail for 2.2.2 & 2.3.0-beta1 on
Debian unstable perl @INC fix (Sebastiaan Couwenberg)
    3627, Encoded polyline functions ignore precision parameter (Christian
Quest / Dan Baston)
    3501, use ST_Union instead of ST_Collect to compute raster max extent
constraint
    3640, Interpolate_from_address sometimes results in "" invalid for
numeric
    3641, Tiger normalize, pagc_normalize integer out of range
    3644, Deadlock on interrupt
    3542, Crash on Geometry(MultiCurve())
    Numerous documentation corrections from ruvyn
    3652,  Segmentation fault during operations on GEOMETRYCOLLECTION with
MULTICURVE geometry inside
Thanks,
PostGIS Development Team
