[postgis-devel] Note to Package Maintainers
Aaron W. Swenson
titanofold at gentoo.org
Thu Oct 6 10:25:18 PDT 2016
On 2016-10-06 15:54, Sebastiaan Couwenberg wrote:
> On 10/06/2016 03:32 PM, Regina Obe wrote:
> > The PostGIS PSC would like to setup a list of package maintainers we'd use
> > primarily for release preannouncements where we deem necessary.
> > This list can take one of two forms, but not sure which people would be most
> > comfortable with:
> > 1) A specific mailing list for PostGIS Packagers
> A separate list is probably overkill, but it is quite convenient to
> contact several people with a single email, and allows the packager to
> unsubscribe when no longer active with postgis packaging.
I like this. This is similar to PgSQL’s packagers list.
> > 2) Just a list of package maintainer that we continually update as part of
> > our repo (with email address if folks are okay with that or link for
> > follow-up) and that would be included as part of source repo.
> > This in part would provide credit to package maintainers and also provide us
> > with our pre-announce go to list.
> This will likely get outdated quickly, and doesn't allow the packager to
> remove him/herself easily when no longer involved.
> > We would also like to update this page:
> > http://postgis.net/install/
> > To include all PostGIS packagers that people use as well as link to their
> > bug tracker if any.
> > Any thoughts on above or updates to the page you'd like to provide us?
> As a packager I have no need for separate calls for packaging as e.g.
> the GRASS project does. I'm subscribed to the development mailinglist,
> and have tooling to monitor for new upstream releases.
> I'm not a fan of separate test releases as was done for 2.3.0 because
> the tarball needed to be downloaded from a different location which
> requires modification of the upstream version tracking which also
> downloads the release tarballs. The final release candidate should be in
> releasable state, renaming it to remove the RC suffix should suffice to
> turn it into the final release.
Typically something like this is beneficial for organizing security
related releases so that as many people/distros as possible will already
have an update available to upload in their respective repos in sync
with the security announcement.
Desc: Digital signature
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20161006/da96eb3e/attachment.sig>
