[postgis-devel] How to develop an infrastructure to test the postgis extension?
Regina Obe
lr at pcorp.us
Mon Oct 17 21:03:39 PDT 2016
Sablok,
You mean running the regular regress checks we do against an extension install.
Use
make install
make check RUNTESTFLAGS=--extension
That will create the test database using extension scripts and then run the same tests.
-----Original Message-----
From: postgis-devel [mailto:postgis-devel-bounces at lists.osgeo.org] On Behalf Of Sandro Santilli
Sent: Monday, October 17, 2016 2:18 AM
To: PostGIS Development Discussion <postgis-devel at lists.osgeo.org>
Cc: sablok <sablok at amazon.com>
Subject: Re: [postgis-devel] How to develop an infrastructure to test the postgis extension?
On Sat, Oct 15, 2016 at 02:26:20PM -0700, sablok wrote:
> I am encountering a problem testing the PostGIS extension. I have
> looked through the monkey garden tests that the community provides for
> testing PostGIS but they only provide some details about the 80K tests
> that they either passed or failed but don't provide us with a decision
> if the PostGIS extension is installed succesfully or not. What is a
> good way to test PostGIS in an automated fashion. Any suggestions
> would be highly appreciated as I need to figure this out real quick.
make installcheck
--strk;
() Free GIS & Flash consultant/developer
/\ https://strk.kbt.io/services.html
postgis-devel mailing list
http://lists.osgeo.org/mailman/listinfo/postgis-devel
