[postgis-devel] ST_AsGeobuf
Javier Santana
jsantana at carto.com
Mon Sep 12 06:20:40 PDT 2016
Hey,
To give some context here about TWKB vs Geobuf: before actually pushing
TWKB to a postgis release we spent a pretty interesting amount of time on
closing the spec (specially Nicklass and Paul) and working on the
implementation so no backwards compatibility changes could happen.
Geobuf is a "format" with no actual closed spec and controlled by just a
single company, they will not mind about changing the spec without any
prior notice (likely not going to happen tho)
Not agains this patch or anything like that, but just to clarify that there
are actual differences between both formats.
On Mon, Sep 12, 2016 at 2:41 PM Björn Harrtell <bjorn.harrtell at gmail.com>
wrote:
> 2016-09-12 10:46 GMT+02:00 Paul Norman <penorman at mac.com>:
>> On 9/12/2016 12:59 AM, Björn Harrtell wrote:
>>> Hi devs,
>>> I've been working on a new output format function called ST_AsGeobuf
>>> these last months. Its purpose is to serialize full query output into the
>>> binary format Geobuf containing both geometry and attributes. The
>>> implementation is tracked by:
>>> https://trac.osgeo.org/postgis/ticket/3599
>>> https://git.osgeo.org/gogs/postgis/postgis/pulls/4 or alternatively
>>> https://github.com/bjornharrtell/postgis/tree/asgeobuf5
>>> Geobuf is a binary format specified by Mapbox that can represent similar
>>> data and structure as GeoJSON but is more compact and is faster encode and
>>> decode. You can read more about Geobuf at
>>> https://github.com/mapbox/geobuf which also serves as the reference
>>> implementation to decode at a browser client side.
>>> Geobuf is in turn based on Googles protobuf standard which I think is
>>> similar to a binary XML. My implementation uses the general purpose library
>>> protobuf-c to simplify the encoding.
>>> I hope to be able use this work as a base to also implement support for
>>> vector tiles as specified by Mapbox which is also based on protobuf.
>>> I think the implementation is ready for review and testing. If you have
>>> any interest in Geobuf or vector tiles output support I'd appreciate review
>>> and/or test result feedback.
>> The MapBox geobuf page states "Note that the encoding schema is not
>> stable yet". Is it premature to put this in PostGIS?
> Subjective, I think. I think Mapbox just want to disclaim backwards
> compatibility in the eventual next major version. Obviously I find it
> useful right now and do think it can be for others too. If needed, PostGIS
> could support both the current spec and future ones by parameterization, or
> drop support if deemed obsolete.
> As far as I know, Mapbox want to evolve the spec so that it can support
> encoding/decoding as a stream, but there is no telling when/if that work
> will be completed.
> And as a final observation, if TWKB could be accepted I think Geobuf
> should be. :)
> /Björn
>> postgis-devel mailing list
>> postgis-devel at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20160912/2c915318/attachment.html>
