[postgis-devel] [Internet] Re: regress test core dumps on Solaris 11
Dechaux Eric CEN (BCQ STIG)
eric.dechaux at gendarmerie.interieur.gouv.fr
Tue Aug 8 00:17:27 PDT 2017
Hello Regina,
You are right, this is version 2.3.3. I am building the same postgis,
gdal and geos versions on both systems.
I was previously using postgis 2.3.1, gdal 2.1.2 and geos 3.6.0 with
postgresql 9.4.10, 9.5.5 and 9.6.1 and gcc 4.8 without coredump during
the checks.
Thank you for the link, this is indeed an issue I encountered and fixed
in an identical manner so I don't think it is related.
Could it be an issue with gdal instead ?
Thanks.
Le 07/08/2017 à 20:25, Regina Obe a écrit :
> Eric,
> Are you running the same version of GDAL on all servers or this is just one server we are talking about that you have 9.4,9.5, and 9.6 all installed on?
> Also looks like you are testing 2.3.3 and not 2.3.4dev. Was that a typo that you meant 2.3.3 or you really were trying to install 2.3.4dev.
> In 2.3.4 (not yet released), we did put in a patch for Solaris, but looking at your trace, doesn't seem to be the same issue.
> https://trac.osgeo.org/postgis/ticket/3795
> Hope that helps,
> Regina
> -----Original Message-----
> From: postgis-devel [mailto:postgis-devel-bounces at lists.osgeo.org] On Behalf Of Dechaux Eric CEN (BCQ STIG)
> Sent: Monday, August 07, 2017 6:13 AM
> To: postgis-devel at lists.osgeo.org
> Subject: [postgis-devel] regress test core dumps on Solaris 11
> Hello,
> I am building postgis 2.3.4 on Solaris 11.3 SPARC and x86_64. I have no issue with postgresql 9.4.12 an 9.6.3 however on 9.5.7 the postgresql server coredumps during the make check regress step :
> PATH is
> /appli/stig/11.3.2017-08-07/pgsql/9.5.7/bin:/appli/stig/11.3.2017-08-07/pgsql/9.5.7/bin:/appli/stig/11.3.2017-08-07/bin:/usr/gnu/bin:/usr/gcc/5/bin:/usr/bin
> Checking for shp2pgsql ... found
> Checking for pgsql2shp ... found
> Checking for raster2pgsql ... found
> TMPDIR is /tmp/pgis_reg
> Creating database 'postgis_reg'
> Loading PostGIS into 'postgis_reg'
> Loading Raster into 'postgis_reg'
> PostgreSQL 9.5.7 on sparc-sun-solaris2.11, compiled by gcc (GCC) 5.4.0, 64-bit
> Postgis 2.3.3 - r15473 - 2017-08-07 07:20:29
> scripts 2.3.3 r15473
> raster scripts 2.3.3 r15473
> GEOS: 3.6.2-CAPI-1.10.2 4d2925d6
> PROJ: Rel. 4.9.3, 15 August 2016
> GDAL: GDAL 2.2.1, released 2017/06/23
> Running tests
> check_gdal .. ok
> load_outdb ... ok
> check_raster_columns .. ok
> check_raster_overviews .. ok
> rt_io .. ok
> rt_bytea .. ok
> box3d .. ok
> rt_addband .. failed (diff expected obtained: /tmp/pgis_reg/test_8_diff)
> rt_band .. failed (diff expected obtained: /tmp/pgis_reg/test_9_diff)
> rt_tile .. failed (diff expected obtained: /tmp/pgis_reg/test_10_diff)
> rt_dimensions .. failed (diff expected obtained:
> /tmp/pgis_reg/test_11_diff)
> rt_scale .. failed (diff expected obtained: /tmp/pgis_reg/test_12_diff)
> rt_pixelsize .. failed (diff expected obtained:
> /tmp/pgis_reg/test_13_diff)
> rt_upperleft .. failed (diff expected obtained:
> /tmp/pgis_reg/test_14_diff)
> rt_rotation .. failed (diff expected obtained: /tmp/pgis_reg/test_15_diff)
> rt_georeference .. failed (diff expected obtained:
> /tmp/pgis_reg/test_16_diff)
> rt_set_properties .. failed (diff expected obtained:
> /tmp/pgis_reg/test_17_diff)
> rt_isempty .. failed (diff expected obtained: /tmp/pgis_reg/test_18_diff)
> rt_hasnoband .. failed (diff expected obtained:
> /tmp/pgis_reg/test_19_diff)
> rt_metadata .. failed (diff expected obtained: /tmp/pgis_reg/test_20_diff)
> rt_rastertoworldcoord .. failed (diff expected obtained:
> /tmp/pgis_reg/test_21_diff)
> Only the rt_addband step coredumps, other tests are failing because the progress instance is restarting.
> The stack trace is :
> $ pstack core
> core 'core' of 29251:
> /appli/stig/11.3.2017-08-07/pgsql/9.5.7/bin/postgres -D /tmp/HayW8S.sh
> ffffffff7da852d4 memcpy%sun4v-hwcap4 (0, ffffffff7fff9fe0,
> ffffffff7fff9fd0, 10098cf98, 0, 10098cf94) + 6c0
> 00000001001f31f0 heap_form_tuple (10098cf68, ffffffff7fff9fe0,
> ffffffff7fff9fd0, 2, 18, 10098cf68) + 140
> ffffffff72959a24 RASTER_dumpAsPolygons (10087f258, ffffffff7fff9751,
> 0, 10, 0, 10) + 85c
> 000000010036abc0 ExecMakeFunctionResult (10087f1e8, 10087f088,
> 100901d38, 100901e50, 1, 10087f258) + 1f4
> 0000000100367bf8 ExecEvalFieldSelect (10087f198, 10087f088, 100901d38,
> 100901e50, 0, 2) + 1c
> 000000010036d61c ExecProject (100901e00, ffffffff7fffa46c, 10087f088,
> 100901d20, 100901d38, 0) + 14c
> 000000010036dad8 ExecScan (1008801e0, 100384214, 10038420c, 0,
> 10087ef78, 10087f088) + 1f8
> 0000000100365aac ExecProcNode (10087ef78, 2, 10087eae8, 100901c40,
> 100860710, 0) + 214
> 000000010036228c standard_ExecutorRun (10087ea58, 1, 0, 100400, 0,
> 10087ee68) + a4
> 0000000100489f74 PortalRunSelect (100860d78, 1, 0, 1008efdb8,
> 10087ea58, 100860d78) + 1d0
> 000000010048b5a8 PortalRun (100860d78, 7fffffffffffffff, 1, 1007b3ad8,
> 1007b39c8, 0) + 34c
> 0000000100487c88 PostgresMain (1007763e8, 1008efdb8, 2, 1007b7170,
> 100860d78, 1007b7060) + 1aac
> 00000001005de0b8 ServerLoop (100758460, 10070e000, 100000, 100186ed8,
> 100000, 1007783c0) + 13b8
> 0000000100421648 PostmasterMain (3, 100755fb0, 100000, 100000,
> 10073f000, 100400) + 1504
> 00000001005df584 main (3, ffffffff7ffff758, 64, 100755fb0, 100400,
> 100750570) + 7f8
> 00000001001ebe74 _start (0, 0, 0, 0, 0, 0) + 7c
> Any idea why this test would crash only with this postgresql version ?
> Thanks
Eric DECHAUX
BCQ / STIG
01 58 66 57 57
Ce message électronique et tous les fichiers attachés qu'il contient sont confidentiels et destinés exclusivement à l'usage de la personne à laquelle ils sont adressés. Si vous avez reçu ce message par erreur, merci de le retourner à son émetteur. La publication, l'usage, la distribution, l'impression ou la copie non autorisée de ce message et des attachements qu'il contient sont strictement interdits.
En cas d'urgence, composez le 17 ou le 112.
Afin de contribuer au respect de l'environnement, merci de n'imprimer cet e-mail qu'en cas de necessite.
This e-mail and any files transmitted with it are confidential and intended solely for the use of the individual to whom it is addressed. If you have received this email in error please send it back to the person that sent it to you. Unauthorized publication, use, dissemination, forwarding, printing or copying of this email and its associated attachments is strictly prohibited.
In case of emergency, dial number 17 or 112.
To contribute to the environmental protection, please print this e-mail only if necessary.
