[postgis-devel] [postgis-users] Postgis version for v10
Regina Obe
lr at pcorp.us
Thu Aug 17 05:37:41 PDT 2017
> Hi Regina,
On Wed, 2017-07-26 at 01:44 -0400, Regina Obe wrote:
>> Typo I meant 2.4 in 9.6 and 9.5
>> 2.4 will support 9.3-10
> We can do that, but that does not prevent the upgrade problem.
Why doesn't this fix the upgrade problem if they UPDATE their PostGIS to 2.4 before doing pg_upgrade
> As a general rule, if we need to make a non-trivial number of changes
> to support a newer version of PostgreSQL in our code-base, we do not
> backport those changes to stable PostGIS branches.
> I don't need the features -- I just need a fix to the compiler errors, so that I can provide the .so file to users.
> Regards,
> Devrim G nd z
> EnterpriseDB: https://www.enterprisedb.com PostgreSQL Danismani/Consultant, Red Hat Certified Engineer
> Twitter: @DevrimGunduz , @DevrimGunduzTR
Any thoughts on my proposal? I think it will fix your issue now and moving forward.
https://lists.osgeo.org/pipermail/postgis-devel/2017-August/026297.html
Thanks,
Regina
