[postgis-devel] Bias in ClusterKmeans
Tom van Tilburg
tom.van.tilburg at gmail.com
Thu Dec 28 07:24:37 PST 2017
When running ST_ClusterKmeans on a large amount (>100) of clusters it
becomes clear that there is a uneven distribution in the clustering, even
when the points are evenly distributed.
Consider the following query:
WITH
points AS (
SELECT
(ST_DumpPoints(ST_generatePoints(ST_MakeEnvelope(0,0,1000,1000),100000))).geom
geom
SELECT ST_ClusterKMeans(geom,1000) over () AS cid, geom
FROM points;
This will generate the following clusters:
[image: Inline image 1]
Obviously, clusters on the lowleft, uppright diagonal are smaller then
clusters further from this diagonal. Could this be an issue with the
starting (random?) seeding?
If people agree this is undesired behaviour (for me it is), I can file a
report.
Best,
Tom
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20171228/0512497e/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20171228/0512497e/attachment-0001.png>
